with my 655 I just use the end to end method where you use the remote's built in ir receiver and copy the signal.Yep I like it. It also fully WAF (Wife approval factor)
I have the MS usb remote contol and keyboard for VMC control. This allows me to change channels on DSTV decoder. The 525 is configed to switch on LCD and sound system with one button and then acts as the MS remote.
Configuring the 525 does take planning and a couple of attempts before you get it 100%. Am now trying to figure out how to get my aircon remote programmed into it.![]()
