Does anyone know where I can buy a 12m optical cable for a pc/amp connection?
I'm currently running coax between the two, but it goes through some electrical wiring, and it is causing interference (the amp will cut out when current in the interfering wiring is switched on or off). I stream quite a bit from my pc to my amp digitally, and moving the electrical wiring is not an option. Thanks
