Looking for a wireless solution
KERU
Jozi
I have a client who has a retail establishment. One of his outlets is around 12kms from the main location.
I am looking for a cost effective wireless solution which can connect the two sites.
I won't be able to use ADSL or 3G for the application.
Any suggestions ?
12 km is a bit of a distance, I'd go for a microwave link if they need high speed, if not, some custom solution at a lower bandwidth. Need more details/specs.
I know the Radwin will do the job but they are hectically expensive.
To even begin to look at solutions, you have to know that there isn't some bloody great big lump of rock (or similar) in the way :p ..so, can you provide the actual physical locations in order for that parameter to be checked?
+1
@OP, do you line of sight?
