Looking for Bluetooth Module for VW
Duan
South Africa.
I am looking to get a replacement Bluetooth Module for my VW with RCD510 radio.
The unit I have is:
5N0-035-730-D UHV-Premium Novero HT-4
I am looking to replace it with:
3C8-035-730-E UHV-Premium Novero HT-5
The dealerships are useless and ridiculously expensive. So... if anyone has replaced a stock head unit in a recent VW, you might be able to help me out.
The unit I have is:
5N0-035-730-DUHV-Premium Novero HT-4
3C8-035-730-EUHV-Premium Novero HT-5
I had one fitted at Motor Music in Craighall. Does all the normal phone stuff plus streaming music from phone with controls. It can do wifi hot spot, but then you need a phone that can do RSAP (Eg Sansung) and a 3G SIM. 4G SIM don't work with RSAP profile on the VW units.
Can also try VAG Tec
How much did it set you back?
The unit I have is:
Maybe check on VWforums
So I ended up replacing my head unit with a new RCD 330.
It works great (mostly) I need to get someone to help me with coding the car for the unit. Anyone able to help?
Often in Midrand, Centurion and Sandton areas.
