Losing connection from Battle.Net
SplaT
Help!
I keep losing connection in the middle of Warcraft III games, for no apparent reason. I have no idea why this happens.
The game times out, and then I get a "You have lost your connection to battle.net" message
My normal internet still seems to work fine when this happens.
It never did that before until a couple of weeks ago.
Anyone know what I can do?
I'm afraid to play again, as it might end in a ban.
Do u have a telkom router ??If u do take it step on it spit on it and throw it away!! NOW!! :P That also happed to me a lot until i got myself a new router d-link never had that problem again:D u can also look if it isn't your router connection that resets.I know your isp resets your connection every 24 hours. If your connection does it more then once in 24 hours i recommend u to call telskum.(Not sure if it will help but give it a go)
If u still have that prob go to www.war3.co.za\forum and look under technical support and see if there's maybe some1 else with that problem.
or just try opening a port ore put of routers firewall and your computers firewall i hade same prob and its a telkom router now its fixed:)
