Low and Gaming PC
The_Unnamed
WUD FTW
Dehben
Looking at building a PC for a friend.
Will be running games like Sims 3 and maybe a few FPS games.
Budget is around R5k excluding screen and keyboard and mouse.
Will this be possible?
Second hand - easily done, can get away with R3k perhaps and have a decent rig
New...
Corsair ±430W PSU R500
HD6850 R1800
CPU R1650
4GB RAM R500
Low end H67 Mobo R1000
Thats R450 over, so sue me :p And tell your friend they must carry over the HDD as well :p Could lower the CPU, I was working on the i5 2400
New...
HD6850 R1800
CPU R1650
4GB RAM R500
Was going to stick in an i3 and the HDD is not a problem.
New...
HD6850 R1800
CPU R1650
4GB RAM R500
No case and what about Windows? Or is he going to find another way, ahem, to get hold of Windows?
I think you can get a 6850 for about R1600 though.
Curses! Just put the mobo on top of its box, worked fine for me :p And erm windows... I assume the person will have a legal copy of it! Right? Right! :D
New...
HD6850 R1800
CPU R1650
4GB RAM R500
+1, best bang for buck here (maximising budget),
Truth is, person does not need to spend R5k in order to do those things.
Prices have just gone up, at least for the decent brands with top after-sales service. But perhaps off brand for R1,600.
So far i have
6850
i3 - 2100
ASUS P8H67-M
2 x 2Gb Kingston Value Ram
Corsair 430W
All at just over R4000.
I have a 1Tb Hard drive lying around that i can put in it.
And there is no need for a DVD-Rom.
Just going to get some cheapy Cooler Master of Gigabyte case. Will stick in a quiet 120mm and all should be good!
The Coolermaster Elite 430 would be the smallest gaming case that I would recommend, and at R430 it is quite good value for your money.
Will check it out. But the case Postman posted looks pretty awesome.
Yes, that case that PP posted looks amazing. A friend of mine recently bought that exact case and he is very pleased with it.
I'm looking at the Corsair Carbide 400R for my next build.
