So the low spec one has a 2.3Ghz i7 with a 256gb SSD and 8gigs of ram for R23999.
The high spec one has a 2.6Ghz i7 with a 512gb SSD and also 8 gigs of ram for R29999.
You can also have an extra 8 gigs of ram added for roughly R4000.
What would you do?
I feel the extra R6k for 256gb and 0.3Ghz might be too steep.
Also don't know if I should upgrade the ram, thing is the ram is soldered into the mobo so you can't have it upgraded at a later stage, but R4k for 8 gigs of ram is really steep.
What would you do?
