Lowest Speed?
Glordit
What is the lowest connection/speed you can play BF2 on? :confused:
I have heard of people playing on 192k, I myself have 64k but BF2 is a no-no! :mad:
thanks for the help!
BF2 uses about 40-50mb per hour.
I don't know if your 64k connection is quite there...
What connection have you got, ISDN? Also, what is the problem with your BF2 connection, lag, timeouts?
Tried once or twice but kep on getting kicked cuase of a 400+ ping, Its a Wireless connection :( but should be getting DSL soon was just wondering :P
I use to play on a 192k connection. Was with Wi-Fi and worked very nicely after I got the pingrate sorted out. My ping was between 150 -900 but was fixed and came down to 60 -80.
Just make sure you dont have anything in the background running like outlook etc.
