LP Gas Conversion kits
orkoza
Potchefstroom
Has anyone done the LP Gas Conversion for their generator. They claim to save you up to 70% on fuel spend. Is it worth the conversion, or is it better to invest in a 5.5kw solar system?
duel fuel systems have been around since the 80s .we converted our whole fleet of cars in the factory to gas allready mid 80s .we converted them all back to petrol again .valve seat recession in a generator may be a problem unless the genie is made for gas ie hardened valve seats .on a 5.5 kw genie i would think you will use 1kg per hour under load minimum .there are many threads on the internet about gas conversions one that stuck in my mind was 9kg gas per day on a genie
  • Like
Reactions: Yuu
What about natural gas conversions? I can run it off dog poo judging by the amount I pick up everyday.
  • Haha
Reactions: Yuu
hahaha. if you add valve ease maybe, im sure someone in the american outback has tried it .mix it with these eco boost fuel tablets you may have a winner
