The Huawei 315 CPE Router is capable of 4G - LTE dependant on Firmware version.Why do you still stay with Vodacom? Just change to Telkom or Rain it will probably be better speeds. Or get a LTE-A router that can do CA between band 3 and 38 and you should be sorted on Vodacom speed wise.
how do you select the correct LTE band?
thanks
