LTE RSRP & SINR Signal
charlieharper
South Coast, KZN
I've been looking at the stats on my Huawei LTE router, and noticed that it bounces up and down like crazy. Is it normal? Or should it be stable?
RSRP:-94dBm
SINR:5dB
Source: https://usatcorp.com/faqs/understanding-lte-signal-strength-values/
Below are explanations of the LTE signal strength values (and also RSSI in relation to LTE):
SINR/SNR – The signal-to-noise ratio of the given signal.
RSRP – The average power received from a single Reference signal, and Its typical range is around -44dbm (good) to -140dbm(bad).
RSRQ – Indicates quality of the received signal, and its range is typically -19.5dB(bad) to -3dB (good).
RSSI – Represents the entire received power including the wanted power from the serving cell as well as all co-channel power and other sources of noise and it is related to the above parameters through the following formula:
RSRQ=N*(RSRP/RSSI)
Where N is the number of Resource Blocks of the E-UTRA carrier RSSI measurement bandwidth.
