mine is a mid 2013 model and on every single day, i have never had a single issue.
Ever
you say it is under warranty? just return it and get it sorted
good luck
damn that suxGot mine in feb. I have heard such bad things about core when repairing Apple products. I’m so scared to take it in and it’s a schlep to “format” my things off. Was hoping it’s something I could fix.
That's a kernel panic, have you installed any software recently ?
If you click report, does it give you any further info?
Not really. Just a few binary things
Besides ESET anti virus and Outlook. And the problems are recent.
You don’t need either of those.
But start with nuking ESET and see if your problem goes away.
Post it here.
Yup. It’s ESET.
Says it right there.
I hope it has a proper uninstall utility otherwise you’ll need to manually go kill off the bad guys hiding in the system folders.
Ugh, at least I know it’s that. So a simple move to bin in finder won’t do the trick?
It may very well do.
If there is no uninstall tool just do that and see how it goes.
Seems you are far from the only one.
If you really feel you must install an antivirus try the Sophos for Mac one. It used to be free and decent but it’s been a few years since I tried it.
