My macbook gets quite hot underneath if I run iTunes and parallels together with a browser open as well. Now I must admit the room temperature is in the region of 31 - 32 degrees so I do not think it is a fault - the CPU temp is around 57 degrees.
I was just wondering if anyone has tried those laptop angled stands that lift the machine off the desk creating a bit of an airflow under the machine as it is quite close to the surface it stands on without a stand. Will this help at all or is it just a gimmick.
My logic says it should help a bit - I am not concerned about the CPU heat - just the physical heat I feel under the laptop when lifting it off the desk.
.....and why is this forum so dead??
any news on Leopards release?
p.s. I eventually got my mini-DVI to VGA converter and hooked it up to my 37" LCD TV last night - beeeootiful..!!
