Magaliesburg problems
Jam Sandwich
Please note that since last week we have been having problems with the connection (Am in the Magaliesburg area, using the Seekoeihoek tower), if you keep the conenction 'alive' i.e. constantly sending data up and down its OK but if you leave the computer and the connection goes into 'idle' then you have to remove the modem, wait 5 minutes or so and then reconnect. Its very frustrating as you think your PC is downloading emails while you are doing other things but meanwhile there is no connectivity.
