Magnet links; DHT and PEX explained.
Chevron
Serial breaker of phones
Joburg
Last time there was a torrent thread here I mentioned using magnet links on bitsnoop.com.
Found something that should explain it for those that dont know:
DHT
Using DHT instead of trackers is one of the things The Pirate Bay is now trying to encourage, and torrent downloads that rely solely on this technology are often referred to as “trackerless torrents.” DHT is used to find the IP addresses of peers, mostly in addition to a tracker. It is enabled by default in clients such as uTorrent and Vuze and millions of people are already using it without knowing.
DHT’s function is to find peers who are downloading the same files, but without communicating with a central BitTorrent tracker such as that previously operated by The Pirate Bay.
DHT is by no means a new technology. A version debuted in the BitTorrent client Azureus in May 2005 and an alternative but incompatible version was added to Mainline BitTorrent a month later. There is, however, a plugin available for Azureus Vuze which allows it access to the Mainline DHT network used by uTorrent and other clients.
Peer Exchange (“PEX”)
Peer Exchange is yet another means of finding IP addresses. Rather than acting like a tracker, it leverages the knowledge of peers you are connected to, by asking them in turn for the addresses of peers they are connected to. Although it requires a “kick start”, PEX will often uncover more genuine peers than DHT or a tracker.
Magnet links
Traditionally, .torrent files are downloaded from torrent sites. A torrent client then calculates a torrent hash (a kind of fingerprint) based on the files it relates to, and seeks the addresses of peers from a tracker (or the DHT network) before connecting to those peers and downloading the desired content.
Sites can save on bandwidth by calculating torrent hashes themselves and allowing them to be downloaded instead of .torrent files. Given the torrent hash – passed as a parameter within a Magnet link – clients immediately seek the addresses of peers and connect to them to download first the torrent file, and then the desired content.
It is worth noting that BitTorrent can not ditch the .torrent format entirely and rely solely on Magnet links. The .torrent files hold crucial information that is needed to start the downloading process, and this information has to be available in the swarm.
Pirate Bay links cf. Mininova links: When the Magnet link specification first came out, in January last year it called for a particular format (“base32 encoded”). The links that EZTV, Mininova and ShareReactor have displayed for some time all conform to that original specification. In May of last year the specification was changed, in favor of “hex encoding”, and that is the format of the links being displayed by The Pirate Bay. Torrent clients should accept either format.
