Magnetic Motor, Dc Motor
DevSign
Hey all,
I am looking for a DC motor, it's for my wind turbine project :D
however, I can't seem to find any sources that sell these second hand, as in the USA they are all over ebay.
If you have a motor that outputs 12V and up, I would appreciate it if you can contact me.
Thanks,
Christopher.
Hey all,
Thanks,
Christopher.
Don't you mean... generator ?
A motor is a generator just going the other way. A generator could be a motor just going the other way ... you get the point.
A bit tricky getting hold of nice DC motors > 12V, basically you are looking for stepper motors, and they tend to be pretty expensive.
I vaguely recall people used to do this with old washing machine engines, tumble driers, even using the motor from a car's window washer or water pump.
Either way, there are a few options to play with: but I would probably go AC and then try to find a few old 12/24/220V AC motors and see what i can do with them. Obviously will need to change your circuits to benefit from AC not DC, or get somebody with more electronics knowledge than I ...
Old motor gate motors might work as well, i.e. Geminis / Centurions or the like. Might be able to pick these up second hand somewhere. These should be 12V+ DC motors.
Good luck finding one.
Also, you should be looking at a permanent magnet motor.
A dc motor is akin to a generator, you give it voltage and it will turn, you turn it and it will give a voltage, not as efficient but it works. Best is to make your own turbine "motor". ;)
Washing machine motors. Have a look a them. I'm not sure as to the voltage they output, but I know they're somewhat popular under the wind turbine bunch in Oz.
Yep, the direct drive type is very sought after, yet expensive.
I am pretty sure he is NOT looking for a stepper motor.
Yea, I wouldn't know: All I know is that usually when I work with DC, I tend to work with steppers, but this is so far out of my line of expertise it's not even funny.
I tended to think that a stepper motor is just a very complicated DC motor, i.e. you have multiple voltages (steps), but in the end it's still just a motor running of DC.
And as mentioned (somewhere), anything I say can and probably is wrong ...
Thanks all, Yeah I really enjoyed reading up on using a washing machine motor....I'll definitely be looking into that.
You can rewire the whole setup
Yup. Someone I worked with who plays around with this sort of thing fairly extensively, added additional magnets. His turbine produces quite a bit of juice when the wind blows, but since he lives in the not-so-windy Freestate, it's mostly idle. It was more of a fun proof of concept for him anyway.
I wasn't quite sure about it. I thought the must be slight differences in their wiring.
I read on this forum that: "...but good motors
tend to make terrible generators"
Here is an article on how to convert a DC motor to a generator.
Use a car alternator.
+1, seems the simplest solution.. If you get one with a built in rectifier it'll output DC or just attach a rectifier. Probably won't get much juice out of it unless you attach it to a gearbox to get it running between 2000 and 7000 rpm but that shouldn't be too hard.
I have an old washing machine and an old tumble dryer at home.
Both the motors still work.
I am in Pretoria, if you want, come get.
Stepper motors are motors that turn in steps as opposed to continually. When voltage is applied to one circuit it stays in one position but moves to another when voltage is applied to another circuit. They are used mainly to precision adjust the position of equipment.
