What do you mean by green light? And what do you mean you need a boost?HI Guys
I have an NP200, the green light on my battery is solid, but I need a boost each time I switch off the ignition?
What could be possible problems?
Kitty
It takes an average of 30 minutes to 45 minutes of driving to fully charge a battery each time you start a car. Small trips may mean that the battery does not get fully charge. Do you have a multimeter. A properly charged healthy battery is over 13 volts. Can you connect the battery to a battery charger and charge overnight. See if that solves the problem.
You learn something new everyday. If you can get a multimeter you can check the battery. This will tell you if your battery is charged or not.
How much are the chargers? Where did you get them from?Then you can charge. Battery chargers can also indicate if the battery is still good:
www.adendorff.co.za
Needing a boost every time could also mean the car is not driven enough to fully recharge the battery.Truth is the inspection eye does not mean much, it is just linked to one cell of the battery and only checks the electrolyte level and nothing else.
I am afraid if you need a boost each time you switch the car off you battery is dead, even a bad battery should be able to start a car after driving. Much has been said about intelligent chargers but I am yet to see a bad battery being brought back to life.
Don't spend your money on a charger, spend it on a new battery. You can buy the charger later.
True.Needing a boost every time could also mean the car is not driven enough to fully recharge the battery.
This is the main reason I got my battery charger. As I was not driving it enough to recharge the battery. And during Covid lockdown, it paid for itself, as I charged both the wife and my car batteries.Needing a boost every time could also mean the car is not driven enough to fully recharge the battery.
My charger has saved my at least 3 batteries and probably a total of about 7k not having to replace it.This is the main reason I got my battery charger. As I was not driving it enough to recharge the battery. And during Covid lockdown, it paid for itself, as I charged both the wife and my car batteries.
I came to post this, but you basically gave the same info and more:Measure the battery voltage when the bakkie is off, fully charged it should not be below 12.6V if below that connect it to a charger. Start the engine and measure the battery voltage it should be in the region of 13.8V if below that have the alternator checked out. Measure the voltage of the battery while the motor is being cranked, it should not drop below 9.6V, if it drops below that its very likely that the battery has seen better days. Check the battery water level, sometimes the maintenance free battery still have the water filling holes, under the sticker or its one long cover that you just pull off.
