Max sell power setting on Sunsynk
Fingerlessliz
Does anyone know where this specific button / option is on the Sunsynk inverter / app and if Sunsynk even has this function?
OK, Thanks that answers some questions but not everything. Since max sell power and inverter power limiter are apparently the same thing, t is there anyway to set the inverter to export a max amount of power, eg. Export until 7000 watt and then stop export?
Well if you set it to 7000W then that's the maximum it will output.
It won't "stop" export, it will just cap it at 7000W.
Bearing in mind this is limited by which model you have, you can't sell 7000W if you are on a 5Kw etc.
