Hi all, some advise required please.
I currently have a 1000va Mecer in line UPs that runs on 2 x 12 volt 9ah batteries (in the box) and and additional 4 x 12volt 9ah external.
they are connected as 3x parallel blocks with (2x battries in series (creating 24volt per block).
i have now acquired a 2000va Mecer in line ups that hosts all 6 x 12 volt batteries in the box, but all videos and tutorials point to a 6 x series connection creating a 72volt system,
However the 2000va system switches off after only 3 minutes (on the series setup), on the same load that could run on the first 1000va setup for 3.5 hours (series and parallel setup) , i have checked and double checked the settings etc and all seems good.
now the question, can i setup the batteries on the 2000va in the same setup 3 x parallel (2 battery in series) blocks and will it run?
any guidance will be appreciated before i blow the circuitry.
Mike
Mike
