Megane II engine torque up arm
Big Lahni
I own a 2005 MeganeII 1.9DCi...2 weeks back it had a clutch problem(it went flat) which Renault fixed for R9000....they said ma thrust bearing failed and replaced the whole clutch.....I have ma old clutch with me but not convinced that its worn out (also they told me the clutch has 2 sides-the driver side and the Tech side....if the driver side is worn out you need to pay all expenses....how true is that):confused:sick:...can sum1 advise wher I can take it to for assesment....
Secondly I just serviced the car a few days after clutch was changed and now they tell me I need to change engine torque up arm.......it is possible it got damaged while they were replacing the clutch or its just old.......car has 90 000km:confused:
