Jase
Greetings all.
I'm a total noob to networking / routers etc.
My WiFi at home has slowly deteriorated over the past few years (specifically the rear AP). Current setup is fibre with a TP-link router hooked up to the ONT. That provides WiFi to the front of the house (Open plan front area with no issues). The back of the house is served via CAT5 cable plugged into a Ubiquiti AP (10/100 iirc). The main issue is the rear of the house has really poor through put (The Signal strength is good).
What I suspect is that the CAT5 has degraded due to heat as the cable is in the ceiling and I have a ceiling gap to the roof of approximately 10cm (In other words no ceiling really to speak of).
Basic house specs:
Size: 200 odd sqm
Older house with lots of layers of paint (if it makes a difference to wifi signal). 3 bedrooms in the rear and a passage leading to the front.
I'd like to go mesh for the convenience of a single access point and a bit of future proofing with gigabit connection and perhaps going a bit along the lines of smart devices down the line. 2.4 and 5.0 ghz needed as I have a few devices that run only on 2.4ghz.
I have around R4k or so to get started.
Any suggestions with links to products would really be appreciated.
Basic house specs:
Size: 200 odd sqm
