Mi Smart Sensor Set
chickenbeef
Item: Xiaomi: Mi Smart Sensor Set
Age: 3 hours, only setup the hub and then found it won't work for my use case. Everything else is unused.
Price: R900
Warranty: Not sure
Packaging: Original
Condition: New
Reason: Received the latest revision of it and found that it's not compatible with HomeAssistant (Works fine with the Xiaomi app)
Shipping: At buyers risk and expense. Add R100
Collection: Yes
Link: Xiaomi Mi Smart Sensor Set
  • 2x Window/Door Sensor Set
  • 2x Human body sensor
  • Multifunctional Gateway
  • Remote control switch
How does these not work with home assistant..?
It is 5LM. There is no way to enable LAN mode and get the token.
If you can, I need the model numbers on the sensors.. I have the coonbee ii ZigBee gateway and they list specific mi sensors as compatible.. I might take it if it's compatible..
Sorry buddy.. somehow missed your post about the model numbers.. looks like they will work for me.. I'll take this off your hands..
Price: R900
Warranty: Not sure
Packaging: Original
Condition: New
Collection: Yes
you can use the sensors with zigbee2mqtt or zha.
You just need a cc debug stick. Can be bought of banggood
Yeah, I saw that but these are the only Zigbee devices I have so it didn't seem worth it to me (R600 shipped for the debugger, sniffer and emulator from Banggood).
I'd rather piggy back off the Sonoff basics I already have installed in the areas I wanted to use these sensors. Won't be wireless of course but much more affordable lol
You don't need anything other than the debugger and an Arduino/esp to flash.
