buffalobill
Anybody know where I can get the power supply? Mine got fried.
Any 5V 2A power supply will work, if you just want to get a USB charger and buy or make a cable the plug is 4.0mm x 1.7mm.Anybody know where I can get the power supply? Mine got fried.
Once you done connecting, just first make sure the polarity with multi meter. Should read 5v and not -5v.Surely the plug did not get fried as well? - just cut it off and connect it to a suitable 5v 2A PSU inner pin +
The insurance assessors took the fried equipment.Surely the plug did not get fried as well? - just cut it off about 3 cm from the plug and then connect it to a suitable 5v 2A PSU making sure that inner pin is +
