micro SD - memory stick Pro duo adaptor
Super78
Hi does anyone know any place I can get these
[ame]http://www.amazon.com/PhotoFast-MicroSDHC-Adapter-Converts-MicroSD/dp/B001H1JF16/ref=sr_1_1?ie=UTF8&s=electronics&qid=1255467702&sr=8-1[/ame]
As well as 2 16gb micro sds
thanx
I've never seen that.
Stick to Sandisk. They have had 16gig microsdhc before anyone else. Remember that class is important, so lookout for class2 for the fast one. If you can afford it, buy Mobile Ultra. Tudor/Cameraland Long St., is the Cape Town distributor.
