but it will still be better then stock sound right?
Esp from golf.
Esp from golf.
ok where would you suggest i put the pair of 6x9's,back or front?Which golf? You can use the citi golf (velociti) standard sound just add to it, the golf 4 up have very very good standard sound.
Save another R1000 and get this...
http://www.autostyle.co.za/prodview.php?prod_id=12547
Theres other combos...
and im talking about the citisport.
The best thing to do is to have it custom built for your car. That way you can consider things like easy access to the spare wheel.
how much would this cost?
