Hi Guys,
Hope someone can help me. I'm not to clued up with mikrotik setup, thought I know my way around winbox & terminal.
I need to setup 2x pppoe accounts on the same wan port. The device is in bridge mode so that shouldnt be a problem. Also, I need the mikrotik to have 2 LAN IP's to use as gateways on client pc's.
So the result should be if I put the gateway & ip range of the client in lets say 192.168.1.0 range it should use pppoe account 1, if I put it in 192.168.5.0 range it should use pppoe account 2.
Any help would really be appreciated.
