Mikrotik Help plz!
headstrong
Hi
I am quite familiar with the linksys wrt54gl that is used as a CPE...
But I have zero experience with Mikrotik!!
Does Mikrotik have similar functions for the same price? Can Mikrotik be used as a CPE for relatively low price??
Does any1 have a pricelist for Mikrotik products?
Thanks!
Hi
Thanks!
MikroTik is the OS that runs on routerBoards and the likes.
Local Suppliers:
Uniterm Direct
http://www.dbg.co.za
(011) 974 5911
Miro
http://www.miro.co.za
(086) 123 1232
(011) 807 7921
From the jawug page. I think miro has a retail pricelist on there website.
The RB112 is generally used as a CPE but with the cost of the RouterBoard and Radio + a pigtail it works out a lot more then a WRT but you get what you pay for.
