Mikrotik RB2011UiAS-2HnD: Activiting SNMP - Help needed
AfricanTech
In front of a computer...
Routerboard O/S: 6.19
I'd like to enable SNMP in order for "Networx" from Softperfect to be able to monitor the traffic at the router level.
Came across these instructions:
Once you have configured the services to your liking it's time to look at other ways to interface with the router, first up is SNMP which is used by a lot of programs to monitor devices (I.e. The Dude)
SNMP is disabled by default and if you have other means of monitoring devices it is safe to leave disabled. I prefer to use The Dude to monitor my network so I will go ahead and enable access and set some helpful fields
Code:
/snmp set enabled=yes [COLOR="#008000"]location[/COLOR]=”The Matrix” [COLOR="#008000"]contact[/COLOR][email protected]
Question from me: What does "Location" refer to and how is it used by RouterOS. Is there a specific name related to my existing network that I need to put in there, or can I put anything in there (same for contact)
Thanks for any insight on offer
