Mikrotik WAN Failover / Bonding
powermzii
Pretoria East
So am trying to setup WAN failover on a hAP AC2. I've tried the guides and videos online but the 2nd WAN connection gets no traffic.
  1. The 2 WANs are RAIN 5G and Telkom LTE
  2. Rain 5G is on Ether 1 and has IP Passthrough enabled so i get a 10.x.x.x address. The route is available and reachable and internet works fine on here
  3. Telkom LTE is to be setup on Ether 2 and here i get a 192.168.8.x address from the LTE router in DMZ
  4. Setup mangle rules to mark the packets and connections for Rain and Telkom on the respective Interfaces for inbound traffic and used the same to point to the relevant outbound interface
When i plug in my Telkom to Ether 2 - no data flows and I lose internet connectivity completely
Followed this video -
Anyone out there able to help? Also happy to post my config
I gave up on the load balancing, never got it to work.
OK after much tinkering i managed to get FAILOVER to work. For those interested - config is below for ROS 6.46.6.
Tested by unplugging the Rain connection and everything switched over to the Telkom one.
Code:
/interface bridge
add dhcp-snooping=yes igmp-snooping=yes name="LAN Bridge"
/interface ethernet
set [ find default-name=ether3 ] comment="Ethernet 3" name=LAN
set [ find default-name=ether1 ] comment="Ethernet 1" l2mtu=1600 name=RAIN
set [ find default-name=ether2 ] comment="Ethernet 2" l2mtu=1600 name=Telkom
set [ find default-name=ether4 ] comment="Ethernet 4" name=VOIP
set [ find default-name=ether5 ] comment="Ethernet 5"
/interface list
add name=WAN
add name=LAN/
/interface detect-internet
set detect-interface-list=WAN internet-interface-list=WAN lan-interface-list=\
    LAN/ wan-interface-list=WAN
/ip dhcp-client
add disabled=no interface=RAIN use-peer-dns=no
add add-default-route=no disabled=no interface=Telkom use-peer-dns=no
/ip firewall mangle
add action=accept chain=prerouting dst-address=10.0.0.0/24 in-interface=\
    "LAN Bridge"
add action=accept chain=prerouting dst-address=192.168.8.0/24 in-interface=\
    "LAN Bridge"
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=RAIN new-connection-mark=RAIN_Conn passthrough=yes
    in-interface=Telkom new-connection-mark=Telkom_Conn passthrough=yes
    dst-address-type=!local in-interface="LAN Bridge" new-connection-mark=\
    RAIN_Conn passthrough=yes per-connection-classifier=both-addresses:2/0
    Telkom_Conn passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=RAIN_Conn \
    in-interface="LAN Bridge" new-routing-mark=to_RAIN passthrough=yes
add action=mark-routing chain=prerouting connection-mark=Telkom_Conn \
    in-interface="LAN Bridge" new-routing-mark=to_Telkom passthrough=yes
add action=mark-routing chain=output connection-mark=RAIN_Conn \
add action=mark-routing chain=output connection-mark=Telkom_Conn \
/ip firewall nat
add action=masquerade chain=srcnat out-interface=RAIN
add action=masquerade chain=srcnat out-interface=Telkom
/ip route
add check-gateway=ping distance=1 gateway=RAIN routing-mark=to_RAIN
add check-gateway=ping distance=2 gateway=Telkom routing-mark=to_Telkom
add distance=1 gateway=10.0.0.1
add distance=1 gateway=RAIN
add check-gateway=ping distance=2 gateway=192.168.8.1
What happens if your internet dies, and not your router?
That check looks like it only checks the next hop gateway and not the internet? What happens if you plug pull out the sim and not switch the router off, does it still fail over?
Good point on this one... Will amend to check something further upstream like cloudflare or opendns
Here is another guide on the Mikrotik Forum, which keeps it short and simple. Typology also comes into play with the way its done, so there isn't really a "one size fits all" solution, but there is always ways to simplify, especially if you use an older Mikrotik that is a little less powerful.
I'm running a 3 WAN Load balance set up, with failover. I use scripts that run once per minute to check an internet IP for each WAN. My set up is a constant work in progress, but I'm happy with the current state.
With multi-threaded connections multiple WANs get used:
Here's an example of one of my Netwatch scripts:
up:
Code:
:log warning "WAN1 up, enabling WAN1_ROUTE";
ip route enable [find comment=WAN1_ROUTE]
down:
Code:
:log warning "WAN1 down, disabling WAN1_ROUTE";
ip route disable [find comment=WAN1_ROUTE]
Routing table is a bit messy, but this may help give you an idea:
With the above script, you'll see if WAN1 fails the Netwatch test, WAN1_ROUTE will get disabled. If you look at all the to_WAN1 routing marks, you'll see that in this case, the next available route would be WAN3_ROUTE with a distance of 2. This is how I handle failover, likely not the best way, but it works.
up:
Code:
down:
Code:
This is nice - i thought about using NetWatch but the steps online seemed complex. I will spend sometime looking into it as it is likely more robust that just using routing for the checks.
Give it a try. Works fairly nicely, just pinging the gateway didn't do much for me. It's worth noting that I've commented on each route so that I can find them within Netwatch. Example WAN1_ROUTE, WAN2_ROUTE, and WAN3_ROUTE
Hi All
I set this fail-over up yesterday and it works fine, you can unplug the cable or turn off the router.
I used a RB951ui. I did not have a dhcp sever setup but you can. First get the config up and running.
I used a static ip of 173.0.0.50 on my laptop.
Then when its all working add a DHCP server to Ether5
Then you can create a bridge and add Ether5 & Wan and then put your Local Lan ip on the Bridge
Copy and Paste this into Notepad: Then using the Find & Replace update the following to your IP ranges:
###You will need to change the following:
###Router 1 (LTE): 10.0.0.1/24 - Mikrotik Ether1=10.0.0.50/24
###Router 2 (LTE): 192.168.8.1 - Mikrotik Ether2=192.168.8.50/24
###Router 3 : (Mikrotik) Ether5=173.0.0.1/24
###Gateway 1 : 10.0.0.1
###Gateway 2 : 192.168.8.1
###prerouting dst-address=10.0.0.0/24
###prerouting dst-address=192.168.8.0/24
###Replace Seacom with Eg: Rain
###Replace Bitco with Eg: Telkom
/interface ethernet
set [ find default-name=ether1 ] name="ether1 - Seacom"
set [ find default-name=ether2 ] name="ether2 - Bitco"
set [ find default-name=ether5 ] name="ether5 - Local Lan"
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip address
add address=10.0.0.50/24 interface="ether1 - Seacom" network=10.0.0.0
add address=192.168.8.50/24 interface="ether2 - Bitco" network=192.168.8.0
add address=173.0.0.1/24 interface="ether5 - Local Lan" network=173.0.0.0
/ip dns
set servers=8.8.8.8
/ip firewall mangle
in-interface="ether1 - Seacom" new-connection-mark=Seacom_conn
in-interface="ether2 - Bitco" new-connection-mark=Bitco_conn
dst-address-type=!local in-interface="ether5 - Local Lan" \
new-connection-mark=Seacom_conn passthrough=yes \
new-connection-mark=Bitco_conn passthrough=yes per-connection-classifier=\
both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=Seacom_conn \
in-interface="ether5 - Local Lan" new-routing-mark=to_Seacom passthrough=\
yes
add action=mark-routing chain=prerouting connection-mark=Bitco_conn \
in-interface="ether5 - Local Lan" new-routing-mark=to_Bitco passthrough=\
yes
add action=mark-routing chain=output connection-mark=Seacom_conn \
add action=mark-routing chain=output connection-mark=Bitco_conn \
/ip firewall nat
add action=masquerade chain=srcnat out-interface="ether1 - Seacom"
add action=masquerade chain=srcnat out-interface="ether2 - Bitco"
/ip route
add check-gateway=ping distance=1 gateway=10.0.0.1 routing-mark=to_Seacom
add check-gateway=ping distance=1 gateway=192.168.8.1 routing-mark=to_Bitco
Hi All
/interface ethernet
/interface wireless
/ip address
/ip dns
set servers=8.8.8.8
/ip firewall mangle
both-addresses:2/1
yes
yes
/ip firewall nat
/ip route
Are you also going to check further upstream as suggested by @webyep ?
up:
Code:
down:
Code:
Dont need to check further upstream it works perfectly. You can turn off the LTE router or pull out any cables and it will fail over. I have a fiber and a LTE modem. If unplug the fiber ONT it fail over to the LTE if I turnoff or unplug the Fiber Modem it fails over. I already check upstream beyond any routers within or on my lan
Understood - i think the use case he mentioned was that f the connection to your ISP is fine but for some reason they can route your request - checking 8.8.8.8 or some other IP would tell you if your Fibre ISP or LTE ISP is down - so beyond the confines of your walls essentially
But good work nonetheless
If you are load balancing - I would maybe add rules for online banking sites etc, they do not like some of your requests coming from 2 diff ip's
Maybe a mangle rule that looks at the TLS host then marks the connection, then have a mangle that marks the route on that connection
I often find load balancing brings more problems than it is worth
I've moved away from the Netwatch script for failover.
On the weekend I encountered an interesting edge-case where an ISP allowed ICMP traffic even though I was capped. I've moved to use "Detect Internet" within Interfaces. https://wiki.mikrotik.com/wiki/Manual:Detect_internet
I added a scheduled script to check the INTERNET interface list and enable/disable accordingly.
Code:
    :global Wan1CurrentState ([:len [/ip route find where comment="WAN1_ROUTE" and !disabled]] > 0)
    :global Wan2CurrentState ([:len [/ip route find where comment="WAN2_ROUTE" and !disabled]] > 0)
    :global Wan1State [:len [/interface list member find where list=INTERNET and interface=WAN1]];
    :global Wan2State [:len [/interface list member find where list=INTERNET and interface=WAN2]];
    :if ($Wan1State = 1 and $Wan1CurrentState = false) do={:log warning "WAN1 up, enabling WAN1_ROUTE";/ip route enable [find comment=WAN1_ROUTE];}
    :if ($Wan1State = 0 and $Wan1CurrentState = true) do={:log warning "WAN1 down, disabling WAN1_ROUTE";/ip route disable [find comment=WAN1_ROUTE];}
    :if ($Wan2State = 1 and $Wan2CurrentState = false) do={:log warning "WAN2 up, enabling WAN2_ROUTE";/ip route enable [find comment=WAN2_ROUTE];}
    :if ($Wan2State = 0 and $Wan2CurrentState = true) do={:log warning "WAN2 down, disabling WAN2_ROUTE";/ip route disable [find comment=WAN2_ROUTE];}
I am assuming it automatically fails over to the other connection when one is down? Do you know if it only checks the availability of a connection on the gateway or some other host upstream?
I had to laugh at how easy this looks compared to our mangles etc..
it basically pings a ubiquti server ( you can change this) and as soon as it cant reach that server ( site) it changes to the next available connection, can have 4 fail overs. As soon as the Primary responds to a ping again, it switches back. We dont even notice anymore when our Vodacom Wireless service goes down anymore.
That's pretty cool
