netstrider
- Nov 1, 2006
So I decided to try one of these.
scoop.co.za
Not sure if the performance below is to be expected or if there's something I need to change on the router itself. The network used is MTN.
In about 50% of the tests conducted, I've got 30 odd ms ping, but then the upload drops to roughly 0.5Mbps when the ping is low. At best I get between 6-10Mbps upload, but a very high ping as above.
On the little MTN ZTE Mifi router, I get this consistently
Both routers are placed on exactly the same spot.
For reference, here's what my phone gets, also MTN and also at the same spot.
Has anyone managed to get decent performance with these MikroTik routers using MTN?
MikroTik wAP LTE Kit 2.4GHz Wireless Router with LTE Modem | wAPR-2nD&EC200A-EU
MikroTik's RB-WAPLTE is a small weatherproof wireless access point with a built-in LTE modem that supports 2G, 3G and 4G (LTE) connectivity. Connect to the wAP’s built-in 802.11b/g/n wireless and access the LTE network from your phone.
