LazerFazer
- Feb 9, 2007
Hi everyone,
Let me start by saying I usually debug my own hardware problems, but this one has me completely stumped. So here's the story:
Last week I passed my old motherboard, CPU, RAM, GPU, and PSU to my brother, and ever since he's been experiencing random rebooting while gaming (random in the sense that sometimes it's immediately after starting a game, while other times it's after 30+ minutes). We've tested the CPU (using Prime95), GPU (Using MSI Kombustor), RAM (Using MemTest 86+ bootable flash disk), and stressed the PSU (using MSI Kombustor and Prime95 simultaneously). Nothing failed any of the tests, nor did the PC reboot at any stage of the tests. We've also updated all the drivers and installed all applicable patches/updates. We've even swapped the RAM modules around without any success.
The strange thing is it's COMPLETELY random. For example, yesterday he managed to game the entire day without having any problems, but the day before and today it's been rebooting.
I'm at a complete loss as to what the problem may be, so I'm hoping one of you will be able to help. His system specs are as follows:
CPU: Intel Xeon E3110 2x3GHz (stock clocks)
GPU: NVidia GeForce 8800GT (With latest drivers)
RAM: 2x2GB + 2x1GB DDR2-800
Motherboard: Gigabyte GA-X38-DQ6
HDD: Samsung HD204UI (2TB SATA-300)
PSU: Huntkey 500W (shouldn't be a problem, seeing as it was used with the exact same components before without problems)
Thanks for your assistance.
Edits:
No blue screens, even though the option to automatically restart is turned off.
I doubt the CPU is overheating, seeing as even running Prime95 for a fairly long time doesn't heat it anywhere close to the critical temperature (I think the highest it got was <60C). Also, the problems happened at two completely different locations: At home and at a LAN, with completely different mains power supplies.
Something I forgot to mention earlier: When the PC reboots it's actually more like a hard reboot, where the PC turns off momentarily then back on again.
The system is a fresh install, just installed it the day we transferred the equipment because he got a new HDD to go with the rest of the system.
The BIOS option for "AC Back Function" is set to "Soft-Off" which is defined as "Always in off state when AC back".
Although it's seeming more and more likely, I can't understand how the PSU would be failing, seeing as a day before the failures started it was running fine in my system with the exact same hardware, except with an HD6870 instead of the 8800GT.
I'll try running PCMARK and 3DMARK as well to replicate the problem in a non-game environment. Results will be up in a few hours.
Edits:
