ODTech
Hi All.
I want to build a steam box i can install next to my consoles in anticipation of the steam controller launching in november (Family from the US is visiting so i'll have them bring one
). The machines has to be as small as possible and preferably a book type case.
I have five requirement for which i found 2 chassis but one of those are too expensive and the other i don't care much for the shape. I'd like to know if anyone can recommend something that is localy available and similar to the lian li chassis i linked below but cheaper. In the end if nothing else is available i'll go with the lian li but i'd prefer not to.
Requirements
1.VGA supported lenght must be 275mm+
Re-Using my GTX670
2.Two expansion bays
VGA Card needs two slots
3.Form Factor iTX
The build has to be a small as possible
4.Standard ATX PSU
Re-using my corsair GS700 PSU (Probably only until i realise i need a modular psu for cable management)
5.120mm Watercooler radiator support
Re-using my watercooler
Here are links to the chassis i've found for reference and incase someone is interested in doing the same.
Ugly case
http://www.chyangfun.com/cfi-a0121bb.html
Expensive case
http://www.lian-li.com/en/dt_portfolio/pc-O6S/
Requirements
Re-Using my GTX670
3.Form Factor iTX
4.Standard ATX PSU
Ugly case
Expensive case
