Mini USB to Standard USB Converter
DominionZA
Edenvale, Gauteng
Hi All,
I am looking for a converter that converts a mini USB to standard USB.
Female on both sides so I can plug the output of a mini USB car charger into the one side, and a standard USB cable into the other.
Been googling for a bit and coming up dry. Any ideas?
TIA
No problem.
I tried thinking of where to get these locally and I came up blank.
I can check with Ends-On tomorrow. Maybe by some chance they have such a thing locally.
I don't mind having to order off eBay. Quite used to importing stuff. I am just in a little bit of a hurry so not into the wait. So ye... If you can find a supplier locally, I would be eternally grateful :)
I checked price list. They have a mini-USB to 2x USB power cable. Don't think that will work.
I'll swing by their office in the morning and see if they some sort of adapter and also find out how much they'd charge to make one up. I mean, it's what they do well. :)
Sorry, didn't get a chance to pass Ends-On this morning and didn't have a moment to give them a call. Physical labour day at the office. :P Will make a decent attempt at it tomorrow morning.
Man, I really appreciate your efforts. Cannot believe you are going to such measures for a complete stranger. Big up man!
No problem. :) Trust me, been there done that trying to find odd connectors in this country and got help left right and centre.
No luck, mate. They have a USB adapter kit, but doesn't look like it has the item you need and costs R200+. :(
