mIRC send/receive speed
guest2013-1
guest
Hi there, no this is not warez related, so **** off.
I only get max 10.5k receive speed, nothing above that. Any idea how I can use my full 512k for receiving? Even if it's just 30kb/s
neone?
I put this under a different post, but it is a good bit of software to use:
Software that was obtained from www.tcpIQ.com for testing the speed of your connection giving and download and upload result
These are my results off a bad connection which hovers around 10% signal strength on my 128kbs mywireless
Test Time Download Speed (KBits/sec) Upload Speed (KBits/sec)
07 Mar 2004 12:24:30 116 49
06 Mar 2004 18:31:21 112 50
06 Mar 2004 14:50:12 121 49
06 Mar 2004 12:27:58 131 42
06 Mar 2004 12:17:32 97 37
06 Mar 2004 12:10:36 102 39
mIRC uses DCC so it depends entirely on the upload bandwidth of the other user. You can also try adjusting the packet size in the settings.
Have you tried to FTP from him? If you get much better speeds then it is definitely something to do with the DCC settings.
