Mortymoose
Greetings to all you techies residing on this floor of our esteemed forum....
Just a fairly simple question:
HO's work Dell Laptop, the HDD is starting to make a vibrating noise, she never told me about this, I accidently discovered it..... The Laptop is about 15 months old....
I wish to mirror her SATA drive onto a new SATA drive and at some stage replace the old with the new...
Is there any good free mirror imaging Software around?
Can I save time by using a software installed and running from a USB stick to mirror the HHD inside the laptop to the new drive plugged into another usb port using a HD Enclosure?
Or should I just stop trying to be clever, use my trusty home PC and plug the two drives into SATA ports and do a straight mirror?
Yawn!
Thanks for reading my yarn!
Yawn!
