Hey everyone, i just need to activate my WiFi again. But i dont know how.
I figured i didn't need WiFi in the area that i am living in and didn't have any use for it for the time being so i deactivated it in Windows Mobility Center.
Some time went by then i decided to reinstall windows 7 64 bit. I'm now in an area where i can use WiFi, only problem is, i cant activate or find it in Windows Mobility Center,
or in Device Manager, Windows did not pick it up after the reinstall because it is still in an off state.
I can't switch it on because there is no physical switch on the laptop either. I think it can only be switched on in the OS.
The laptop that I am using is an Acer 7740G.
Thanks in Advance.
Thanks in Advance.
