Mobo power connector and power switch header
have u plugged in your cpu power?
go look around your cpu for 4 plugs assuming your mobo is new
2 rows is fine it just means your board is entry leven the other 2 rows for more powerful mobo's
your ram connected?
Number one, your power fitting to the motherboard is not sufficient. If the power supply doesnt have a slide in socket on the side of the 20 pin power plug to enlarge it to 24 you are stuffed and should get a new PSU or get an adapter. I would just get a new PSU wtih the right 24 pin fitting...
Some reading:
http://mybroadband.co.za/vb/archive/index.php/t-47599.html
http://www.endpcnoise.com/cgi-bin/e/std/sku=20to24
http://www.cooltechpc.com/c/ctpc/std/sku=00444.html
Number two:
Read the manual wrt where the reset plugs etc should go. Download a manual if need be.
