Modem Ethernet cable.
Whooooaaa
These are a "dime a dozen". Just a regular cross over cable would do - find your nearest pc chopshop or incredible ripoff... should do fine...
In fact, depending on your NIC, you may even be able to use a regular straight through flylead as most do auto polarity switch these days...
Actually
Then WHY are you calling it an ETHERNET cable if it is NOT an ethernet cable
