Monitor keeps losing signal on T260?
CorneN
I have the most annoying issue with my display. It 'loses signal' and you either get the 'no signal' block when you have Source on manual, or it constantly jumps between different input types if you have Source on automatic. There is no real pattern to it. it will act up one minute, and then work brilliantly for hours.
At first we I thought it was an SLI problem, so I removed one card. Still happened. Then I rolled back drivers and it still gives me the same crap. Just saw now that it does the same thing through boot as well, so definately not an OS / Driver problem.
Has anybody had similiar problems before?
Have you tried replacing the cable? It sounds like either a bad connection in the cable or a dry joint on the connectors of either the GPU or the monitor. Maybe mess with the cable/connectors and see if that is the cause?
I had the same thing with the T260 via DVI. It would work one day and fail the next, completely random.
Switched to HDMI and it worked fine(before selling it).
