Monitor problems
trapjaw
Pietermaritzburg
Hey guys
I have an Acer AO 533 netbook, and recently I've connected a Samsung monitor to it. It worked fine the first time, but now every time I try to plug the monitor in, it will go on for one second, then the screen goes black and won't turn on again.
The monitor also used to do this to the PC it was connected to when someone logged off or switched users.
I have not changed or done anything with my video or display settings.
Any idea what's wrong?
How old is that monitor? I had similar problems with Fujitsu monitor. Discovered there were a few failing caps & had them replaced, problem solved...
