MyWorld
If you ever watched a movie then you know that sometimes the screen will just go blank on you even though you turned off the screensaver.
Well, try this next time:
https://wiki.archlinux.org/index.php/Display_Power_Management_Signaling
Set screen blank time to 1 hour instead of the default 5 minutes:
Turn DPMS (display power management signalling) off:
You can also try:
To check if DPMS is off:
Code:
xset s 3600 3600
Code:
xset -dpms
You can also try:
Code:
xset -dpms;xset s off
Code:
xset q
Keyboard Control:
auto repeat: on key click percent: 0 LED mask: 00000002
DPMS (Energy Star):
Standby: 111 Suspend: 166 Off: 222
DPMS is Disabled
