Most silent 120mm fans...
pjoub06
Looking for 3 of these fans but they must be silent...like no noise whatsoever!Any suggested?Btw I dont care for leds, or any of that crap. Just want effective,silent fans.
Have a look at Noctua or Scythe fans. You can order them from overseas here:
www.performance-pcs.com
Its gonna cost you, but if you want silent and move lots of air, that's the price you have to pay.
First of all, silent usually measn low RPM, and low CFM, you can achieve this by using a speed controller, but from what I have heard, Noctua NF-12 is very good and quiet.
Noctuas are great, very quiet and still with a higher CFM ratio than most other fans, even on slower speeds.
Look here in the classified section if you want to purchase.
Wish someone was selling those Noctuas second hand because they are really expensive...They seem amazing however!
For a fan?You can buy a zalman 120mm for R65.Obviously not as quiet/efficient but still. 3 times the price...
I use the vantec stealth/vizo 120mm's in my system which seem rather quiet :)
these fans are amazing
just amazing
silent
I disagree I find them to be louder than my Zalmans, but if you want silence get a good speed controller, I'm running my 120mm fans at 550 rpm and they hum along nicely.
Silence :)
I meant not a bad price if compare to the usual price we paid in SA for other quality components. Maybe it's not what you looking for :D
Are those fluid bearing? because at that price I'll only consider fluid.
Fluid bearing are the most silent fans you can get and last much longer but I can't find any such fans in SA. :(
Silence :)
Presently running 4 Vizo's with the side of the case open and less than 30cm from my right ear and it is a pleasant hum :)
They are not bad I must say but I've used better ;)
The cooler master silent series I find to be the best value IMO, cheaper than the Zalmans but quieter.
These Noctua fans use a Self-stabilising oil-pressure bearing (SSO). It is supposedly better than fluid bearing ;)
