Motorola Defy MB525 BIG Problem, HELP PLSE!!!!!
Henlou1
Hi there guys, i bought this phone on Bidorbuy and the guy never told me that it's gonna come from china, so i got the phone and of course everything was in china, after fiddling with the thing i got it to english, used it for about 3 days them came across the hole de-branding with new firmware, got a post and follow all the steps to flash it with RSDLite, the program said success, 100%, passe, phone being rebooted, and that's all it does, only white LED and nothing else, not even recovery, bootloader NOTHING!!!!!
Checked everywhere on the WEB, flashed a number of sbf's but gives me the same story, can ANYONE please help
THNX :confused:
Sounds like you bricked your phone. Sorry to hear mate :(
I have the same phone, but I don't have much experience with flashing a new ROM. Maybe you should ask in the Motorola Defy Thread - some guys there might be able to help you.
You need to find an sbf that has the same "CG version" as the Chinese sbf that was on your phone - you've tried flashing lower "CG version" sbf's - and that's why your phone won't boot. Don't despair - I was in the exact same position. Be careful though, if you keep trying to flash without success your battery will eventually go flat the Defy doesn't charge when it's not booted into Android. There are workarounds to charging the battery, but it get's complicated.
I'd recommend you read this (especially the bit explaining sbf's and CG versions).
For more general information about your phone, take a look here:
Defy wiki
Good luck!
