You can also get some brilliant results with ConvertXtoDVD (but it is not free).
I just converted a file using DVDFlick. Seemed fine, worked on my PC. But when I put it into a DVD player, it didn't work.
Did you "close the disc" ?
You must check that setting in your burning software.
Yeah I closed the disc. Will try play around with it a bit more this evening.
