MSN/Skype audio recording
scatlett
Westville, Durban
Does anyone know of a good program that allows you to record msn/skype audio chats? Both sides of the conversation?
For Skype I just set my computer to Stereo Mix and call, for bout 5 - 15 seconds at the start of the call, the person you called can hear themselves, but then goes away. You can use any program to then record the strereo mix stream.. audacity is a good opensource answer.
I've used free a program called " Scanner recorder" & "Recordpad Sound recorder" and both are simple and work fine.
