One of my friends are also playing on 3g but logged last nigth saying he has 3k ms was not playable.
I am kinda getting better ms since the patch dont know if its blizzard or did telkom improve somehow.
Had 280-360ms yesterday for more than 2 hours.
Never happened before.
Use to get 380-550
I am on adsl unshaped 4 mb line.
I started playing wow on 3g 2 years ago the latency was great.
400-600ms but after 1 year they just got bad so i had to get adsl.
Ok from what i can figure out it seems the DC occurs when the MTN 3G device changes from HSPA to 3G. Now it is the same signal so I have no idea exactly how it affects the WOW connection. I have sent an email to WOW Tech Support as well, as it seems there are people in other countries also having a similar problem.
Any feedback on a solution will be great.![]()
you want a solution? try this. No matter what 3G/HSDPA device u use (Except if you use your cellphone), If you using the application that came with the device you have the option to choose what your connection must be. On default its set to HSDPA Preferred but will accept 3G and Gprs connections. Just set it to use HSDPA only and it should help. Mine never goes from turquoise to dark blue... dunno just my opinion.
I'm using the application that came with my E220. Where do you find the setting for this?
