MTN EDGE Bypass
jargon7
Johannesburg
Good day,
This thread is for all those people who are stuggling to pick up 3G signal and are only getting EDGE even though you are in a 3G reception zone. I have discovered a simple solution for blackberries that support 3G reception to bypass the phone picking up EDGE and force 3G, this worked like a charm for me. I have a Blackberry 9900 Bold.
WARNING: if you go out of a 3G reception area, your phone will lose signal and keep searching for 3G until in a 3G reception area. It will not automatically go back to EDGE.
Here are the steps:
Goto: Options > Networks & Connections > Mobile Network
Then change the setting:
Network Selection Mode: Automatic
Change it to 'Manual'.
Your phone will search, and you will see MTN brings up 2 options to choose from:
* MTN 2G H
* MTN 3G H
Select the 'MTN 3G H' and wait for it to connect.
There you go. Permanent 3G.
To change back, just choose the automatic setting again.
Hope this helps somewhat.
Thanks. Interesting to know. I switch my 3G off and keep the phone (BB B9900) on 2G otherwise my battery wont last for the day. Really crappy but i try not to use the BB for search/internet.
Aaaaaahhhh dude, you are awesome man !! Worked for me.
Thanks A LOT !! Wohooo...
