MTN - problem with logging into mxit - GPRS errors
thegov23
Hi Guys
I need some help...cos MTN cant provide them...
I have reloaded my sony ericsson w900i software and tthereafter got my gprs settings to download Mxit.
all that was successful...problem is because im an existing user on mxit it says to login when i enter my cell number then my mxit pin then the security code and select accept it... gives error stating GPRS settings incorrect try again...
My GPRS settings are correct else i wouldnt be able to access the internet from my phone...
please help its proving costly to try all the options of continuously re downloading Mxit and smsing *123*13#
What else can i do that will resolve this issue?
:sick:
I can't log into mxit via MxitPC. for some reason i've got the incorrect cell number and password... Don't know why but this keeps happening, maybe mxit server has some problems.
you need to set which internet profile to use for Java apps
settings " Settings for Java"
Hi Guys
:sick:
i've got the same problem ... don't think its anything to do with my settings ... or my phone rather it's a mxit problem .... it doesn't recognise you on a new or recently repaired phone ...
