MTN VoIP Not leagal on their network.
munkiller
In terms of the current regulatory regime in South Africa, please note that these tariffs and the MTN GPRS, GPRS+, EDGE or 3G technologies may not be used to transfer or generate Voice over Internet Protocol (VoIP) traffic. Should it be found that VoIP traffic was carried over the MTN network using these tariffs or technologies, MTN reserves the right to cancel the agreement that you have with MTN, with immediate effect. You will also be charged retrospectively at R21.93 per Megabyte (VAT excluded) for any VoIP traffic transferred by such means.
SHOCKING!!!!!!
http://www.mtn.co.za/Default.aspx?pid=232081 look right at the bottom
How can they possibly know that you are using voip? I would like to see them try.
Dam and I just got skype working on my i-mate
MTN is a service provider, and they supply internet sevice to you. you can use it for what you like within boundaries.
But if they have a problem with that, you can tell then then you would just have to switch service providers.
MTN does not charge R21.93 per mb . This was already discussed in detail on this forum...The MTN rep at the time said that it was just on paper but not implemented at all.serach for the thread
