Multi Player Games without split screen
LilJohn
Hi Guys
Can you please recommend Xbox 360 games which you can play with 1+ player without split screen and not online. Was thinking of buying Homer Simpsons the game not sure though if it allows more then one player. Really looking at playing with my nephews over holidays.
Do you mean non-split-screen as in the Lego games perhaps? Like Lego Star Wars where you and your partner play on the same screen in co-op? My kids enjoy Lego:SW and more than one person can play at a time. There's also Viva Pinyata, but the multiplayer is a bit odd: two people can play at once with two controllers, but you're both basically controlling the same screen with two different controllers - turns into a tug of war sometimes.
Split-screen Multi-player is usually PvP, whereas same-screen MP is often co-op. You also get some hot-seat type of games (mostly board-games) where each player takes his turn using the shared controller.
Juice
Juice
Thanks Juice will look into Lego Star Wars. Wonder if Enslaved can be played as co-op since it says co-op at back will try when I get home later.
Marvel Ultimate Alliance 1 and 2 are pretty good. Same with any other top-down game.
